1998 GMC Suburban Sputtering/Choking during accelleration
1998 GMC SUBURBAN
R3CON
Engine Performance problem
1998 GMC Suburban V8 Two Wheel Drive Automatic 150k miles
This problem is blowing both the minds of dealership mechanics, no-name mechanics, and me. Long story short; When I start the vehicle it runs perfectly fine. After about 10 minutes of driving at 35+ mph it no longer lets me accelerate. When I press the gas, it either chokes out and jerks or nothing happens at all. When I pull over, turn the vehicle off, and start it up again immediatly, the problem is gone and it runs good again.
Sometimes it wont let me accelerate to 10mph, sometimes it wont happen until I am doing 50 and trying to accelerate to 60.
There is no SES light on. Every mechanic has told me that its in surprisingly great shape for its age. Yet, none of them can figure out the issue. Im trying to narrow it down before I go spending hundreds of dollar fixing one thing after another trying to find the issue.
Feb 24, 2010 at 5:39 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 24, 2010 at 5:49 PM
R3CON
[quote:da3ca9af98="rasmataz"]Inspect and test all the following listed below:
Oxygen sensor.
EGR Valve
False air leakage.
Fuel contamination.
Cap and rotor.
Note:If it doesn't apply disregard.[/quote:da3ca9af98]
Ugh.. Its so much to check :( ... I do really appreciate it though. I just wish I were more mechanically inclined so I could feel comfortable doing all this without paying someone to help or do it for me.
Feb 24, 2010 at 6:08 PM
