1998 GMC Suburban 4x4 not engaugeing
1998 GMC SUBURBAN
187,000 MILES • V8 • 4WD • AUTOMATIC
I have replaced the front axle mounted acuator, the transfer case motor and the dash push button assm. and still nothing. when I turn the truck on all the lights will blink on the push button and then go off for a few seconds then the red nuetral light and 2wd and 4wd low lights will stay on ????????? Does this truck have a " Transfer case control module" ??? and if so could that be the problem and where is it loacated. I also noticed that when I was put up the elec. windows the lights on the 4x4 push buttons would dim down.
Feb 6, 2010 at 9:13 PM
FACTORYJACK
  • 4,159 POSTS
The transfer case control module is under the left side of the dash, by the steering column. If it is a non auto selectable FWD, you can ground pin 13 at the diagnostic connector(it is an orange wire), and the switch LED's should flash codes(If any) It would only be 1-4. It sounds like you may have a module faulty. Does the vehicle have any aftermarket stuff installed?
Feb 8, 2010 at 11:39 PM
