Im having trouble with my radiator and the lines ... I recently installed a new radiator and connected both upper and lower oil lines to the radiator. connected both upper and lower tranny fluid lines to the radiator. vehicle ran for about three miles and the transmission dis-engauged . I loosened the lower tranny fluid line going into the radiator and the tranny en-guages but now im loosing tranny fluid from that lower line...seems to be some kind of vaccume or pump problem but idk?? there is fluid coming from the line when the cars in drive but when its attached snug with the radiator the transmission wont engauge at all....nada. Theres no flow. do i need to bleed the tranny lines like you would the brakes? What did i do wrong installing this radiator? can you help me???
Jan 1, 2010 at 3:29 PM
