1993 GMC Suburban 1993 Suburban No Heat
1993 GMC SUBURBAN
131,000 MILES • V8 • 4WD • AUTOMATIC
SCOTTYMCDEE
  • 11 POSTS
I asked this question before in Feb 09. Since I live in Florida it wasn't a big deal. Still no heat, here's what I've tried.
It has frt/rear heat, so I by-passed the rear hoses to frt only heat. While the hoses were unhooked to the frt core, I used my garden hose on the inlet side and had full pressure water out of the outlet hose, so I know the heater core isn't clogged. I replaced the thermostat with a correct 195 and the temp gage reads 195 and lowers as the thermostat opens/closes. The radiator is full, correct antifreeze mix. Now the problem. The outlet hose of the heater core runs to a metal tube which connects to the back of the engine by the distributor. If I put garden hose pressure on this metal tube it doesn't flow. I removed the thermostat from the engine and tried it again and still no flow. What exactly does this metal tube in the back of the engine do? Is it coolant that runs through the block back to the water pump? When I touch the heater hoses they are slightly warm due to engine bay heat, not coolant. The metal tube stays cold even after a trip to the store. I'm stumped.
Jan 3, 2010 at 1:22 PM
DOCFIXIT
  • 18,828 POSTS
Hi
The metal lines should be two runn coolant to rear heater core.. Did you unhook hoses from rear core and connect together? Is vacuum operated heater control valve opening ?
Let me know
Thanks for donate
Jan 3, 2010 at 1:51 PM
MERLIN2021
  • 17,250 POSTS
The metal tube tapped into the block is just the fitting for the hose to attach to, try reaming it out with a wire coathangar, could have rust or corrosion blocking the flow. Or the impellers on the pump may have dissolved over time, it does happen!
Jan 3, 2010 at 1:53 PM
SCOTTYMCDEE
  • 11 POSTS
I'll try reaming the hose, it has no flow at all. Thanks.
Jan 5, 2010 at 6:04 AM
SCOTTYMCDEE
  • 11 POSTS
I've bypassed the tubes to the rear heat, flushed water through those lines and everything was fine. IF it gets warm outside I will ream the block tube, process of complete elimination leads to the metal tube to the back of the engine. Yes, all vacuum operated doors etc are working perfectly. The block tube is ice cold after trips around town.
Jan 9, 2010 at 4:46 PM
SCOTTYMCDEE
  • 11 POSTS
Rear coolant line located on the back of the intake by the distributor was plugged.
Mar 7, 2010 at 11:23 AM
MERLIN2021
  • 17,250 POSTS
So all is well?
Mar 7, 2010 at 11:40 AM
SCOTTYMCDEE
  • 11 POSTS
I broke the quick connect hose (like everyone else does) that went into the back of the intake manifold and scratched my head on how to fix that problem. I finally decided to get an older chevrolet heater hose connection (the one that comes out of the top of the water pump on the old chev's) I tapped the ID of the old broken pot metal quick connect due to the fact that the ID of the broken one is approx the same tap drill size. Tapped the threads for the new connector into the pot metal, used ultra black sealant, and worked like a charm.
Mar 16, 2010 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
Believe it or not, it's 1/2" pipe thread...good work!
Mar 16, 2010 at 2:22 PM
SCOTTYMCDEE
  • 11 POSTS
i scratched my brain for a good 1/2 hour before I came up with that fix. glad I've worked around motors back in the day and remembered that connector.
next question. why doesn't my electronic controller work in the dash now? worked for 2 weeks after i fixed the hose problem previously, then the dash unit died. I have all power to the back of the unit, checked all fuses AND fusible links in the engine compartment on the firewall. still nothing. stumped on this electronic crap. i've got an old manual linkage controller from my 72 pickup, wish i could put that in there....
Mar 16, 2010 at 3:35 PM
MERLIN2021
  • 17,250 POSTS
Do you mean the blower does not run? Or controller does not turn the blower, or switch the registers air flow?
Mar 17, 2010 at 3:09 PM
SCOTTYMCDEE
  • 11 POSTS
doesn't light up on the display, doesn't run the blower, doesn't change the blower doors, does absolutely nothing. the blower motor isn't running, its like the whole heater control system died. but I have power to it, I checked the relays, I've had the whole dash apart checking for shorts and found nothing. Replaced all fuses, checked voltage through all fusible links, all have power. i am stumped.
Mar 17, 2010 at 4:02 PM
MERLIN2021
  • 17,250 POSTS
Simple fix would be a junkyard replacement. I have no info on repair of the controller, all manufacturers just replace the unit.
Mar 17, 2010 at 4:48 PM
SCOTTYMCDEE
  • 11 POSTS
I did that, working unit, still doesn't work in my truck. obviously somewhere I have a short.
Mar 22, 2010 at 5:59 PM
MERLIN2021
  • 17,250 POSTS
Check the ignition switch, not the cylinder, but the plastic block the electrical harness plugs into.
Mar 23, 2010 at 12:30 PM
