If I remove the steering colum can I tighten it back up to fix the movement in it or does it need relaced
Mar 10, 2010 at 11:20 AM
DOCFIXIT
CERTIFIED EXPERT
Tilt steering wheel? if yes pull it apart put Lock-Tite on bolts that hold tilt mechanism to column.
Mar 10, 2010 at 2:30 PM
VEGASMSTRJ
MEMBER
had the same issue with my c10. i had to bring it to a mechanic to replace a few worn parts. they suggested i let a pro do it because it is pretty complicated.
