airbag reset
GMC SONOMA
BROO102
2000 gmc sonoma with 65,000 miles. I had the carpet replaced and ever since then the airbag light will not distinguish.
How do you reset it?
Bruce
Sep 20, 2007 at 6:49 PM
BMRFIXIT
  • 19,053 POSTS
[quote:a19e0f1706="broo102"]2000 gmc sonoma with 65,000 miles. I had the carpet replaced and ever since then the airbag light will not distinguish.
Bruce[/quote:a19e0f1706]
check to see if you have airbag codes
once the problem resolved light will go out
you need a scaner
most shops will charge about $45
you can have them pull the codes and reset it at the same time but i think you have a problem in the system or maybe something disconected
codes will help
Sep 20, 2007 at 7:17 PM
BROO102
I plugged in my OBD II scanner & "NO CODES" came up. It only reads engine codes.
What can I do next?
What are points?
Bruce
Oct 4, 2007 at 6:26 PM
BMRFIXIT
  • 19,053 POSTS
hi Bruce
did you try to scan BCM for codes
you need to scan air bag system
Oct 5, 2007 at 4:57 AM
DMPRAG01
  • 4 POSTS
[quote:659b632090="broo102"]2000 gmc sonoma with 65,000 miles. I had the carpet replaced and ever since then the airbag light will not distinguish.
Bruce[/quote:659b632090]
did you check to see if it's unplugged behind the dash. i had the same issue and all i had to do was plug it back in
Oct 6, 2007 at 8:40 PM
