2004 GMC Sonoma rear rotors
2004 GMC SONOMA
PAT ROHRICH
Brakes problem
2004 GMC Sonoma Four Wheel Drive
cant remove rear rotors
Dec 30, 2009 at 12:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the brake caliper. Do not disconnect the brake hose from the caliper. Support the caliper with a piece of wire to prevent damage to the brake line.
Remove the brake pads.
Remove the brake caliper mount.
Remove and dispose of the sheet metal rotor retainers.
Remove the brake rotor. If needed, bang on the rotor with a rubber mallet to loosen. Inspect the brake rotor for wear or damage. Refinish the brake rotor if necessary.
To install:
Clean the axle flange.
Install the brake rotor.
Install the brake caliper mount.
Install the brake pads.
Install the brake caliper.
Burnish replaced or refinished rotors.
Jan 13, 2010 at 2:24 PM
