2002 GMC Sonoma GMC Sonoma Code p0301
2002 GMC SONOMA
23,000 MILES • 4 CYL • 2WD • AUTOMATIC
SNCDOC
About one every 4 to 5 months I get the code P0301, #1 cylinder misfire. It almost always sets when the truck is idling. The code clears after about 50 miles and then doesn't return for another 4-5 months. I've replaced the #1 spark plug with no change.
Also I read in the Shop Manual that this code is sometimes thrown for the automatic when it is traveling on a bumpy road and the crank shaft and cam shaft gets off. I do have a long bumpy driveway, but the code doesn't usually come as I'm driving down the drive. There is a slight misfire sound when it is idling.
Any clues as to where to look?
Doug Simmons
Mar 11, 2009 at 12:02 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:01157448cc="sncdoc"]Engine Performance problem
2002 GMC Sonoma 4 cyl Two Wheel Drive Automatic 23000 miles
About one every 4 to 5 months I get the code P0130, #1 cylinder misfire. It almost always sets when the truck is idling. The code clears after about 50 miles and then doesn't return for another 4-5 months. I've replaced the #1 spark plug with no change.
Doug Simmons[/quote:01157448cc]
Hi Doug,
Well either you type the code i wrong or you looked up the wrong code not sure which but here is the Code Def for what you have listed...
P0130 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 1)
Mar 11, 2009 at 12:07 PM
SNCDOC
The code should be P0301, #1 cylinder misfire.
Sorry for the confusion.
Mar 12, 2009 at 11:24 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:76c1ba9a2d="sncdoc"]Engine Performance problem
Doug Simmons[/quote:76c1ba9a2d]
Hey Doug,
Ok, have you tried changing the #1 plug wire with another plug to see if the code moves from the #1 cylinder?
Check fuel pressure and fuel regulator.
Check for Vacuum Leaks.
check compression
check coil.
Mar 14, 2009 at 9:55 AM
SERPENTRACER
  • 34 POSTS
check the crank position sensor.
notorious failing part on these trucks that causes the missfiring codes.
does the plug have any white soot deposites? this would indicate a lean cylinder possibly caused by a dirty fuel injector.
(from personal experience)
Mar 14, 2009 at 3:37 PM
SNCDOC
I hadn't thought about the crank sensor. I'll definitely check that first.
The spark plug I took out looked normal, at least from my experience with normally functioning plugs. No soot, and just a slightly gray coating.
I'll try the crank sensor next since that is one of the easier things to check.
Mar 15, 2009 at 9:43 AM
