2002 GMC Sonoma ecm
2002 GMC SONOMA
197,000 MILES • 4 CYL • 2WD • MANUAL
100THOMPSON
I do not have power to the diagnostic connection for the scanner tool. I have checked every fuse in both fuse panels. The scanner will read codes if I put a battery in it but it will not clear the codes. The truck runs fine (although the check engine light is on). I tried the scanner in another truck and it worked as it should have, powered by the diagnostic connection. Were does the diagnostic connection get power from in an s-10?
Oct 5, 2010 at 9:11 PM
BMRFIXIT
  • 19,053 POSTS
Check if your cigarette light working as the should be on the same fuse fuse # 2 with key on it should have power on both side use a test light and check it
https://www.2carpros.com/forum/automotive_pictures/99387_2_2.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_1_2.jpg
Oct 6, 2010 at 5:50 AM
100THOMPSON
THANK YOU.
Oct 6, 2010 at 12:46 PM
BMRFIXIT
  • 19,053 POSTS
Welcome
thank you for the donation
Oct 6, 2010 at 1:02 PM
