2000 GMC Sonoma CLUTCH
2000 GMC SONOMA
PATRICK H LIVELL
Transmission problem
2000 GMC Sonoma Two Wheel Drive Manual
HOW DO YOU BLEED AND FILL THE CLUTCH ON THIS TRUCK AND WHAT IS THE RIGHT FLUID FOR IT.
May 16, 2009 at 11:08 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Patrick, The Clutch Master Cylinder is under the hood and should be in the area of the Brake Master Cylinder... The Clutch Master looks like this....
https://www.2carpros.com/images/question_images/199285/original.jpg
To Bleed the System you have to crawl under the vehicle follow the plastic line to the Clutch Slave Cylinder it is integrated inside the tranny bellhousing and it right behind were the line connects. In the pic below the larger line is the fluid connection and the smaller one is the Bleeder....
https://www.2carpros.com/images/question_images/199286/original.jpg
May 16, 2009 at 11:18 AM
