1999 GMC Sonoma timing
1999 GMC SONOMA
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
DTRAIN
  • 12 POSTS
I pulled the distributor to change the lower intake manifold gaskets. Then truck was moved so the timing has been disturbed. I have the turned the crank by hand to line up the first mark on the harmonic balancer with the mark on the timing chain cover. I dropped the distributor in and checked to see if the rotor was aligned with the #6 on the distributor. It is off by about 3/8". I aligned the mark on the timing cover with the second mark on the harmonic balancer and checked the rotor and it was about a 1/4 turn off. Do I need to adjust the oil pump with a screw driver to get the rotor aligned properly and is the computer attempting to get the timing corrected in the process?
thanks
[img:0678dfe686]http://www.2carpros.com/forum/automotive_pictures/373813_IMG00013201005122058_1.jpg[/img:0678dfe686][img:0678dfe686]http://www.2carpros.com/forum/automotive_pictures/373813_IMG00013201005122058_2.jpg[/img:0678dfe686]
May 13, 2010 at 10:11 AM
DTRAIN
  • 12 POSTS
i got it thanks
May 14, 2010 at 5:03 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry we didnt get to you soon enough......... glad you figured it out though. Thanks for using 2Carpros.com
May 14, 2010 at 7:58 AM
