I tried to start my Sonoma and nothing happened. I pulled the battery, had it checked (was bad) and replaced it. Same condition - turn the key, nothing happened.
Pulled the starter and found the wire connecting the starter motor to the solenoid was broken. Replaced the starter. The engine cranks over but does not start.
Replaced the distributor cap/rotor and the fuel filter. No change. The ignition coil was replaced about a year ago. I tested it with an ohm meter and it checked out.
The fuel pump will engage to prime the system when the key is turned. I have not checked the fuel pressure at the schrader valve at the intake yet. I did try starting fluid but it did not work.
Thanks in advance for your help.
Jun 25, 2009 at 5:58 AM
