I need to replace the turn signal flasher (the fuse is fine, the hazard lights still flash). The diagram from the GM parts desk does not provide enough detail to locate the unit in the engine compartment. There is a second flasher under the dash, again insufficient detail is provided. Any directions to locate the flasher would be greatly appreciated. Vehicle has over 180,000 miles.
Thank you.
Thank you.
Mar 17, 2006 at 8:39 AM
