1997 GMC Sonoma hood release cable
1997 GMC SONOMA
TROY CODD
Noises problem
1997 GMC Sonoma 4 cyl Two Wheel Drive Manual
how do i chanage the cable broke the rest is fine
Feb 21, 2009 at 10:51 PM
DONGMLQ
I replaced mine by getting the replacement part which is the whole cable assembly. Took the old one off, it was held by only 2 screws under the steering wheel, and pulled the broken cable through the fire wall. I also attached a strong string to the end of the old cable and used it to bring the new cable back the way the old cable came out as there are some tight places for the cable to run through. There was also a seal in the fire wall that has to be popped out. It can be done with simple tools and common sense.
Good luck
Oct 14, 2009 at 11:27 PM
