1996 GMC Sonoma won't start till dash lights come on
1996 GMC SONOMA
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
GMC_SONOMA
about half the time i try to start my truck the engine will turn over but won't start, i've noticed that when it doesn't start the dash lights (check engine, abs, brake...)are not on. sometimes after cranking over for awhile the dash lights will suddenly come on and instantly the truck starts and runs great. most of the time i have to turn the key several times to get the lights to come on. on a couple of occasions i have been driving down the road and the truck will die and all the dash lights go off. i know i'm getting fuel because i can smell it after cranking for awhile. any advice would be greatly appreciated. thanx
Jul 21, 2009 at 6:19 PM
Could be coming from the ignition switch get it tested-
Jul 21, 2009 at 6:26 PM
GMC_SONOMA
[quote:300d758be2="rasmataz"]Could be coming from the ignition switch get it tested-[/quote:300d758be2] thanks for the input, thats the first suggestion that made any sense. i've got a chilton manual but it doesn't say anything about the ignition switch. can you test it without removing it? once again thanks for the help.
Jul 22, 2009 at 6:18 PM
