96 Sonoma, running problem. OBD II code 303 - cyl 3 misfire. All plugs are carbon fouled, plugs less than 9 mos old, plug wires brand new. Truck idles rough, check engine light will flash when engine is run hard. Possible guesses are coils not producing enough spark, causing rich running and one of the coils failing casing the cuy 3 misfire. Only other guess was a bad throttle position sensor. Any ideas?
Apr 11, 2009 at 11:28 PM
