1995 GMC Sonoma gas tank
1995 GMC SONOMA
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRB1212
need to change gas tank not totally sure how
Jul 30, 2009 at 8:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Properly drain the fuel tank, then disconnect the negative battery cable.
If not done already, raise and support the rear of the truck safely using jackstands.
If equipped on late-model vehicles, loosen and remove the tank plastic shield.
Loosen the retaining clamp and disconnect the tank filler hose from the tank neck.
If fuel and vapor hoses or pump/sending unit wiring can be accessed at this time, they may be tagged and disconnected. If not, wait for the retaining straps to be loosened and lower the tank slightly for access.
Tag and disconnect and accessible wiring or hoses from the top of the fuel tank.
Have and assistant support the fuel tank, then remove the fuel tank-to-vehicle straps and, if equipped, the isolation strips. If no assistant is available, position a floor jack to support the tank while the straps are removed.
Lower the tank slightly, then remove the sending unit or sending unit/pump wires, hoses and ground strap. Be sure to label all connections to ease installation.
Carefully lower the fuel tank from the vehicle and store in a safe place.
INSTALLATION:
Raise the tank partially into position in the vehicle. If you are working without an assistant, you may wish to loosely install one of the retaining straps and use a floor jack to support the tank at an angle so there is access to the sending unit or sending unit/pump assembly (as applicable).
Connect the fuel/vapor hoses and wiring to the top of the fuel tank, as tagged during removal.
Carefully raise the fuel tank so it is fully into position and loosely secure the retaining straps. Make sure the wires and hoses are not pinched or damaged when raising the tank. Also, be sure that the isolation strips (if used) are positioned between the retaining straps and the fuel tank.
It may be easier to connect the fuel filler hose to the tank neck at this time. If desired, connect the hose and secure the clamp.
Tighten the fuel tank retaining strap fasteners to specification. Tighten the strap nuts to 33 ft. lbs. (45 Nm).
If not done earlier, connect the tank filler hose to the tank neck and secure using the clamp.
If equipped, install and secure the tank plastic shield.
Remove the jackstands and carefully lower the rear of the truck.
Refill the fuel tank and install the filler cap, then check for leaks.
Connect the negative battery cable.
Jul 30, 2009 at 11:02 PM
