what do i need to stack off to install?
I think the alternater,But can't seem to get it to?
Dec 14, 2009 at 3:05 PM
SWILLIAMS
CERTIFIED EXPERT
Nothing to remove or loosen on a 94. There is a tensioner assembly that is spring loaded. It is down on the lower left side of the engine. There is a 1/2" square hole you put a breaker bar into and then rotate the tensioner away from the belt. Then the belt can be removed.
