1994 GMC Sonoma Fan belt installation
1994 GMC SONOMA
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
STARKHERE
what do i need to stack off to install?
I think the alternater,But can't seem to get it to?
Dec 14, 2009 at 3:05 PM
SWILLIAMS
  • 597 POSTS
Nothing to remove or loosen on a 94. There is a tensioner assembly that is spring loaded. It is down on the lower left side of the engine. There is a 1/2" square hole you put a breaker bar into and then rotate the tensioner away from the belt. Then the belt can be removed.
Dec 18, 2009 at 12:56 AM
