1991 GMC Sonoma vacuum
1991 GMC SONOMA
G BOWMAN
Engine Performance problem
1991 GMC Sonoma 6 cyl Two Wheel Drive Automatic 116.00 miles
i have no vacuum from my pcv valve to my throttlebody.the line is clear
Apr 11, 2010 at 9:10 PM
HMAC300
  • 48,601 POSTS
you probably have junk in the pipe ging to the throttle body. if you get some choke cleaner and spray it in there and let it soften the junk up a little then just shove it into the intake and hook up the hose. Although change your pcv valve if you haven't already and make sure y our hose going to the throttle body isn't soft. You may hear some noise with the carbon smacking around after you start the engine but it won't hurt anything. You might need a small screwdriver to drive the stuff into the manifold but take your time and twist the screwdriver like a drill, but don't use a drill....
Apr 18, 2010 at 5:40 PM
