1991 GMC Sonoma Leaks
1991 GMC SONOMA
225,000 MILES • 6 CYL • 2WD • MANUAL
I have oil leak at rear of engine. Oil leaves a puddle after truck is parked a few minutes. Is there a seal at rear of engine that would remedy problem by replacing it.
May 6, 2008 at 3:14 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You may have a failed rear main oil seal, if so the transmission will have to be removed to replace, or it may be the sump leaking, best to have it washed down and inspected first to verify where the leak is.
Mark (mhpautos)
May 6, 2008 at 5:59 PM
