what are causes of an internal engine coolant leak
GMC SIERRA
LOVETORQUE
1999 GMC Sierra, K10753, 5.3L V8, auto trans, 104k miles, regular 4500 to 5000 mile oil changes with Mobil 1 5W-30, very minimal towing hauling of any weight. Used oil analysis says high Potassium (161) and Sodium (32) means coolant contamination.
Found Tech Service Bulletin, 06-06-01-019B, on bad heads that have porosity / cracking in area of oil drain "bowls". I am going to take valve cover off to inspect for this bad cyl head issue.
What other causes of coolant leaking down into the crankcase should I be considering, besides bad head gaskets? Thanks a bunch.
Oct 26, 2007 at 3:48 PM
Could be crack head and block-an intake manifold gasket between the head and manifold.
Oct 26, 2007 at 4:09 PM
