Noisy steering only on left turns
GMC SIERRA
GMC 2004 Sierra 59000 miles.
I have a noisy steering problem, happens when only making left turns, this usually happens at slow to moderate speeds making a left turn at intersections.
The belts are good and fluid levels are good.
Jun 3, 2006 at 9:00 AM
SYNCRAIT
  • 235 POSTS
what do you mean when you say noisy what kind of noise? a clunk, a click, a screech, plop, boing, ribbit
Jun 3, 2006 at 1:33 PM
whining noise, like a flat guitar
Jun 3, 2006 at 3:22 PM
LSUSSEL
  • 252 POSTS
A whining noise is an indaction that you need to add more power steering fluid and or that your rack of pinion is going, when you add this power steering fluid make sure you turn the steering wheel all the way to the left as far as it will go and then all the wheel all the way to the right as far as it will go, to get all the air out of the lines. hope this helps.
Jun 4, 2006 at 1:12 PM
