gmc sierra running rough is there diagnostics in heater disp
GMC SIERRA
ELISAB
i have a 1997 gmc sierra with 190,000 miles.It has been running great till went on a road trip .about 6hrs away.then it started running rough.So had new plugs put in new distributor cap and rotor.also new fram air cleaner.still running rough.seems to run smoother when the ac is on.Is there a way to check computer diagnostics through the heater display?any other ideas?HELP!!!
Aug 14, 2006 at 5:54 PM
MIKEYBDMAN
  • 623 POSTS
[quote:f340f6f921="elisab"]i have a 1997 gmc sierra with 190,000 miles.It has been running great till went on a road trip .about 6hrs away.then it started running rough.So had new plugs put in new distributor cap and rotor.also new fram air cleaner.still running rough.seems to run smoother when the ac is on.Is there a way to check computer diagnostics through the heater display?any other ideas?HELP!!![/quote:f340f6f921]
Check your Mass air Flow sensor. If that gets a dirty or oily build up on it, it can trim the engine fuel mixture and make it run bad.
Aug 14, 2006 at 7:25 PM
