1994 GMC Sierra 4.3L V6 200,000 miles
I have been experiencing an intermitent hesitation or stumble in my truck. In park idle seems fine. When cold runs fine. When warm, problem occurs sometimes, and beginning to happen more often. Happens stopped in drive gear, or when at constant speed, but most often and noticable when accelerating. Replaced plugs, wires, fuel filter, O2 sensor, PCV valve, EGR solenoid and valve recently. Distributor, rotor, and fuel pump 40k old. Also, the air filter was covered in gas. Checked timing: at 8 degrees BTD ECM plugged in with +/- 2 degree "wobble" at idle.
Feb 25, 2007 at 6:23 PM
