Is this vehicle equipped with, or still have heated washers? If it does, for starters check this bulletin that may apply for the failure. There was also a campaign issued to disable that system, so there are no longer parts available to repair it.
#PIT4298: Unwanted Wiper and/or Washer Operation - keywords erratic heated intermittent phantom spray unwanted washer windshield wipe wiper - (Feb 26, 2007)
Subject: Unwanted Wipe and/or Washer Operation
Models: 2007 Cadillac Escalade, ESV, EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that windshield wiper and/or washers will not shut off, when equipped with RPO XA7, heated windshield washer fluid. Root cause may be leak at o-ring connector (X2) at the windshield washer solvent heater pigtail that allows washer solvent to wick down the harness.
Recommendation/Instructions:
A production fix was implemented on February 12, 2007. For service, replace the windshield wiper heater module P/N 15897902
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
#10153B: Product Safety - Heated Windshield Washer Module Short Circuit - Permanently Disable and Remove Module - (Jul 20, 2010)
Subject: 10153A - Heated Windshield Washer Module Short Circuit - Permanently Disable and Remove Module
· A T labor code for customers who refuse to have the recall performed. This labor code will NOT close the recall. If a customer refuses to have the recall performed, dealers are to provide the customer with a copy of the "Notice to Customer" document contained in this bulletin, record on the repair order "customer declined recall repair" and, if possible, have the customer sign the repair order. Request that the letter be placed in the vehicle glovebox for future reference by subsequent owners. If at a later date the customer, or a new owner, decides to have the recall performed, perform the repair and submit the claim using the appropriate V labor code.
Condition
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2006-2009 model year Buick Lucerne; Cadillac DTS; HUMMER H2; 2008-2009 model year Buick Enclave; Cadillac CTS; 2007-2009 model year Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, Tahoe; GMC Acadia, Sierra, Yukon, Yukon XL; Saturn OUTLOOK; and 2009 model year Chevrolet Traverse vehicles equipped with a heated washer fluid system (RPO XA7/CHW). A recall was implemented on some vehicles in 2008 to add a fuse to the HWFS control circuit harness to address the potential consequences of a printed circuit board electrical short. However, there have been new reports of thermal incidents on HWFS modules after this improvement was installed. These incidents resulted from a new failure mode attributed to the device’s thermal protection feature. Their significance varies from minor distortion to considerable melting of the plastic around the HWFS fluid chamber. In some circumstances, it is possible for the heated washer module to cause a fire.
Correction
Dealers/retailers are to permanently disable and remove the heated washer fluid system and compensate the customer for the loss of the feature.
Vehicles Involved
Involved are certain 2006-2009 model year Buick Lucerne; Cadillac DTS; HUMMER H2; 2008-2009 model year Buick Enclave; Cadillac CTS; 2007-2009 model year Cadillac Escalade, Escalade ESV, Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, Tahoe; GMC Acadia, Sierra, Yukon, Yukon XL; Saturn OUTLOOK; and 2009 model year Chevrolet Traverse vehicles equipped with a heated washer fluid system (RPO XA7/CHW), and built within these VIN breakpoints:
Important: Dealers/retailers are to confirm vehicle eligibility prior to beginning repairs by using the Investigate Vehicle History link. Not all vehicles within the above breakpoints may be involved.
For dealers/retailers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided to US and Canadian dealers/retailers through the GM GlobalConnect Recall Reports, or sent directly to export dealers. Dealers/retailers will not have a report available if they have no involved vehicles currently assigned. .
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this recall is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this recall.
Oct 18, 2010 at 11:11 PM
