2007 GMC Sierra check engine light on trouble code p0449
2007 GMC SIERRA
77,000 MILES • V8 • 2WD • AUTOMATIC
CARTER96
  • 17 POSTS
My check engine light came on a few weeks ago and it would not come on some times until I drove for awhile. Now it stays on all the time. I had the code read and it came out p0449. How do I go about trouble shooting what the problem is. It happened right after I changer the spark plugs, wires, and the battery so I might have knocked something loose but I cant seem to find anything. Any help would be great.
Jul 1, 2010 at 5:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
DTC P0449 : Evaporative Emission (EVAP) Vent Solenoid Control Circuit
This code is common to appear if the battery was disconnected for any reason. I suggest erasing this code from the system and waiting to see if it comes back. If it does come back then the EVAP vent solenoid valve may be faulty.
Jul 1, 2010 at 9:06 PM
CARTER96
  • 17 POSTS
How do I erase the warning code. I disconnected the battery but that did not do it. Also how difficult is it to change the evap vent solenoid never done one of those.
Jul 2, 2010 at 11:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to use a diagnostic scan tool (or have local auto part store do it) to erase the codes stored. The solenoid should be mounted on the back side of the tank. From under the truck you can remove the valve wiring connector, remove the valve from the tank and remove the lines from the valve and canister. If there is no hose on the new valve, then use 5/8 heater hose to run the filter for the valve beside the transmission.
Jul 2, 2010 at 1:42 PM
