2003 GMC Sierra instrument panel cluster warnings
2003 GMC SIERRA
13,000 MILES • V8 • 2WD • AUTOMATIC
SZALKUSKT
  • 274 POSTS
On the bottom of the instrument panel cluster in th e green digital numbers it says "Driver 1" and also I get a "change oil" warning sometimes. How do I reset the Oil Change warnings and also what Does "driver 1" mean?
Jun 16, 2010 at 8:30 PM
2CARPRO JACK
  • 11,533 POSTS
Driver 1 is in the setting for preferences.In the manual it will explain that you can program seat position and keep track of mileage for a specific driver.For theoil change reminder, turn key forward to on position, with engine off.Pump throttle all the way to the floor 6 times rapidly.The oil reminder should flash then reset itself
Jun 18, 2010 at 8:30 AM
SZALKUSKT
  • 274 POSTS
look in the owners manual?
Jun 24, 2010 at 2:38 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, look in the owners manual.If you dont have one, you may be able to find an online (PDF) version.As I explained it is to be able to set preferences such as seat position and keep track of mileage for more than one driver.Does your vehicle have steering wheel controls? If so there should be amenu button you can push to go through the menu for the options.
Jun 25, 2010 at 7:49 AM
