2002 GMC Sierra power windows
2002 GMC SIERRA
97,000 MILES • V8 • 4WD • AUTOMATIC
CRNUG019
Last night I replaced the motor on the drivers side window of my 2002 GMC Sierra 2500HD. Once replaced I tried to roll the window and it makes a sound as if something is wrong withe the wire tat wraps around the part which the motor goes into. The window will roll all the way up making this sound the entire way up but the motor is unable to bring the window down. When it goes up you are also able to move it down with your hands. Im thinking there may be a problem with how I wound the wire back up after taking the motor out. Any suggestions?
Thanks!
Oct 1, 2010 at 6:41 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like you have something broken on the regulator or something put in wrong.The regulator with motor is only 69 plus shipping so i would have replaced the whole thing not just the motor.Here's how you replace the motor.
Front Side Door Window Regulator Motor Replacement
Removal Procedure
1. Raise the window. If the window motor is inoperable, remove the window to gain access to the window motor retaining screws. Refer to Front Side Door Window Replacement (See: Front Door Window Glass\Service and Repair).
2. Remove the power window module. Refer to Front Side Door Window Module Replacement (See: Front Side Door Window Module Replacement)
3. With the window regulator on the bench, remove fasteners one (1) and two (2) which will disconnect the drive housing and motor (4) from the rail (5).
Important: Do not allow cable gear/spool to come out of the housing. As the motor slides out of the gear/spool, hold the gear/spool into the housing with your fingers. The spool will unwind if it comes out of the housing.
4. Holding the motor and housing together, remove fastener three (3).
5. Slide the motor partially out of the gear/spool allowing finger access to the gear spool (6). Hold the gear/spool into the housing and remove the motor (7).
Installation Procedure
1. Install motor by aligning gear teeth and mounting points simultaneously, pushing the motor into the gear/spool and installing the motor to housing fastener first (3).
2. Slide the motor and housing assembly (4) onto the rail (5) and install the fastener number two (2).
Notice: Refer to Fastener Notice .
3. Rotate the motor and housing assembly to align the attachment point for attachment number one (1) and install the fastener.
Tighten the bolts to 5 Nm (44 lb in).
4. Install the power window module. Refer to Front Side Door Window Module Replacement (See: Front Side Door Window Module Replacement).
5. Install the window if removed. Refer to Front Side Door Window Replacement (See: Front Door Window Glass\Service and Repair).
Oct 1, 2010 at 11:44 AM
CRNUG019
Thats the problem the cable did pop out and it came unwound haha what should I do?
Oct 1, 2010 at 5:45 PM
SATURNTECH9
  • 30,869 POSTS
You need to replace the regulator anyway you can return that motor you bought?They sell the motor and regulator for 69 plus shipping at www.rockauto.com plus if you put this code in how did you hear about us box you will save 5 percent off your order.Here is the number 40220433242193.
Oct 1, 2010 at 7:03 PM
