2002 GMC Sierra No pressure Coming from the injectors
2002 GMC SIERRA
SELECT
Computer problem
2002 GMC Sierra V8 Four Wheel Drive Automatic
I have a 2002 GMC Sierra Heavy Duty 6.6 Turbo Diesel.
I changed the crank sensor, but it will crack, but not turn over. The main problem is getting the vehicle started.Do i need to re-program the ECM once i changed this sensor? I hooked up a pressure gauge and there is no/very little pressure coming from the injectors. I've also try placing the suction line in a pale and there was no pressure.
If you could provide some feedback that would be great
Thank you in advance.
Sep 29, 2009 at 9:17 AM
BRIAN 1
  • 1,030 POSTS
we have alot of problems with the injection pumps on these,very common.also check the fuel filter for contamination or water.check for any dtc's.
Sep 29, 2009 at 5:20 PM
