Truck was parked two nights ago with low fuel. Next time I tried to start it, it would not. I assumed the 10 month old fuel sending unit went bad and warrantied the sending unit(oem part). Made no difference. I have noticed the fuel gauge doesn't work(currently has about a half tank of fuel) and the highlight on shift indicator that tells what gear it's in is no longer there. "Fuel" fuse shows power on both sides with key on, "Fuel" relay shows no power at all where it would plug in to fuse box. I jumped from DRL relay to fuel only to get truck home and it did start. However, once i put truck in reverse to move it, truck died and i'm back with the same problem. Any advice??Thank you for your time.
Aug 26, 2010 at 6:09 PM
