2002 GMC Sierra Clutch
2002 GMC SIERRA
156,000 MILES • 6 CYL • 2WD • MANUAL
STEVE_THOMPSON
Clutch pedal sits about 1/2 " off floor. Bled off no change in pedal height. In order to shift you have to stand on the pedal, it will hold without slipping. The guy I bought it from said he replaced the clutch 4 mos ago. There isn't any visible leakage in the system that I can see. Could it be an internal seal leakage to the Master cylinder? One thing I did notice, without the pedal depressed the slave cylinder moved around when I was putting the wrenches to it.
Jul 6, 2009 at 11:53 AM
ED_12ROD
  • 12 POSTS
You would need to check the screwa first if theyre tight then the clutch master cylinder is goin bad. Or another option is have a mechanic check if its the right linkage cable.
Aug 7, 2009 at 8:50 AM
