2002 GMC Sierra brakes
2002 GMC SIERRA
177,563 MILES • V8 • 2WD • AUTOMATIC
MOMMA54
when i bought the truck 2 years ago it just had a brake job done, now if i stop 2 or 3 times then stop again the pedal doesn't want to go down so i changed the brake booster because it was bad but it still does the same thing, can you help?
May 21, 2010 at 11:07 PM
HMAC300
  • 48,601 POSTS
check your brakes, they are probably worn. If you go to the site here there is a step by step instruction on how to change your brakes. Look under repair on the right side of the site.
May 25, 2010 at 5:05 PM
