2001 GMC Sierra window issues
2001 GMC SIERRA
BIGK151
I have a 2001 GMC Sierra with ~80k, and power windows. Yesterday I rolled down my drivers side window and heard a crackling sound. When I went to roll up the window, it only rolled up about 1/4 way but would go back down fine. I ended up having to force the window up. Does this sound like the power window motor?
Dec 5, 2006 at 8:34 PM
CARUNDELL
  • 602 POSTS
[quote:8d1be29bde="bigk151"]I have a 2001 GMC Sierra with ~80k, and power windows. Yesterday I rolled down my drivers side window and heard a crackling sound. When I went to roll up the window, it only rolled up about 1/4 way but would go back down fine. I ended up having to force the window up. Does this sound like the power window motor?[/quote:8d1be29bde]
Hey bigK
That style truck has a whole "window regulator/motor assembly" and its cable operated, its quite a "contraption". And a pretty lengthy task if your up to it, rivets need to be drilled out etc.....but I would recommend taking it to a trusted shop for repairs.
Regards,
Chris
Dec 6, 2006 at 6:25 PM
BIGK151
Thanks for the information Chris.
Dec 6, 2006 at 7:31 PM
GMX
  • 37 POSTS
IT'S EASY BY THE WAY THERE IS NO RIVETS ON A 2001 THEY STOPED PUTTING RIVETS IN 2000 & THAT WAS ONLY THE LIMITED ADITION TOHOE OTHERWISE LEFT OVER 1999 TOHOES WITH FLARES 16" RIMS . THERE IS ONLY 10MM BOLTS FOR THE REGULATOR & 2 7MM SCREWS FOR THE DOOR PANEL .
Dec 7, 2006 at 9:14 PM
GREGGESTEY
  • 4 POSTS
I've had both the passenger and driver side windows have this issue. It's a little over $400 a window fixed by the dealer. The first time I took it all apart and after looking at it I gave up and took it in.
Dec 11, 2006 at 4:11 PM
CARUNDELL
  • 602 POSTS
[quote:2d410e9a94="GMX"]IT'S EASY BY THE WAY THERE IS NO RIVETS ON A 2001 THEY STOPED PUTTING RIVETS IN 2000 & THAT WAS ONLY THE LIMITED ADITION TOHOE OTHERWISE LEFT OVER 1999 TOHOES WITH FLARES 16" RIMS . THERE IS ONLY 10MM BOLTS FOR THE REGULATOR & 2 7MM SCREWS FOR THE DOOR PANEL .[/quote:2d410e9a94]
Thanks for the update GMX!
Chris
Dec 11, 2006 at 4:21 PM
