P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
Need to inspect your Mass Airflow (MAF) sensor. Suspect if may be faulty. This will usually cause poor power, poor idle and/or poor fuel mileage.
Thanks for using 2CarPros.com!
Feb 24, 2009 at 1:50 AM
CHRIS HENRY
MEMBER
thanks but the truck has a new m.a.f. sensor and map sensor
Feb 24, 2009 at 8:12 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Try unplugging it and see if it makes the vehicle run better. If it does then there is still a problem with it somewhere. Either wiring or something is dirty and not letting the sensor do its job correctly.
