2000 GMC Sierra POPING AND THUMPING
2000 GMC SIERRA
226,000 MILES • V8 • 2WD • AUTOMATIC
PATRICK333
WHEN I TURN RIGHT IT MAKES A POPPING SOUND SOMSTIMES BUT ONLY WHEN IT'S MOVING. AND WHEN I GO OVER BUMPS OR HOLES I CAN FEEL A THUMP IN THE FLOOR.
May 30, 2010 at 2:05 PM
2CARPRO JACK
  • 11,533 POSTS
At that mileage I would inspect all bushings to be sure they are still intact.Check sway bar end links and center bushings, shock bushings as well.It is something solid if you can feel it in the floor.Also lift and support front end and check for play in the wheels, to be sure the wheel bearings are good (noise turning right). Generaly it just needs a good front end inspection to see whats wrong, if it is that bad, hopefully it is obvious
Jun 1, 2010 at 7:55 AM
