2000 GMC Sierra Idling at 3,000 rpm
2000 GMC SIERRA
WHCHERRY
Transmission problem
2000 GMC Sierra Four Wheel Drive Automatic 155,00 miles
I just had the serpentine belt and a new tensioner put on. The next day the truck began to accelerate without me applying pressure to the gas. With the brake all the way pushed down, the slowest the truck would go was 5 mph. I put it in neutral, it was still revving so I put it in park and turned it off. After a few minutes it was fine, but once I began driving again the same thing happened. When I left it in park and turned on the engine would run at 3,000 rpm. I tried pulling the gas pedal, but i figure there must be something wrong under the hood.
Sorry for the long explanation and any help is greatly appreciated.
Jun 10, 2010 at 2:29 AM
MHPAUTOS
  • 31,937 POSTS
Petrol or diesel?
Mark (mhpautos)
Jun 10, 2010 at 2:43 AM
WHCHERRY
Gas. Thank you very much for the response.
Jun 12, 2010 at 6:23 AM
MHPAUTOS
  • 31,937 POSTS
Clean throttle body, check for engine vacuum leaks, check that the IAC is working correctly, the idle is controlled by the ECU, do a scan as well to check for any unresolved fault codes.
Mark (mhpautos)
Jun 12, 2010 at 7:26 AM
