1999 GMC Sierra metallic popping noise in 4x4
1999 GMC SIERRA
135,000 MILES • V8 • 4WD • AUTOMATIC
METZA1
When I have my truck in 4 wheel drive (4-lo or 4-hi) and I accelerate quickly or I’m putting a lot of torque on the vehicle, there is a loud metallic popping noise. It sounds like its coming from the front end, but I’m not 100% sure. During normal driving (straight or turning left or right) there is no noise.
May 20, 2009 at 8:56 PM
DR LOOT
  • 2,311 POSTS
it is obvious its coming from the drivetrain, check all of your u-joints including the front axle, and make sure you check your mounts like your transmission and transfer case, and check your engine mounts while you're at it, any other questions let me know check all of your u-joints including the front axle, and make sure you check your mounts like your transmission and transfer case, and check your engine mounts while you're at it, any other questions let me know"
May 20, 2009 at 10:26 PM
