This fuse runs two major components. The starter relays and in turn the starter.
Then the ignition switch. So, if you take a look at the wiring diagram below of the power flow for this circuit we need to find out if any of the other fuses like the ignition 1 or turn fuse are blowing.
If only the IGN A fuse is blowing and the starter, starter relay has been replaced and it is still blowing then the ignition switch is most likely shorted causing a direct path to ground and it blows the fuse.
Basically, we just need to remove the fuse and check for a short to ground.
If it is there, then disconnect the switch and see if it goes away or to an open circuit.
If it does, then I would replace the switch because the issue is between the fuse and additional fuses and this switch is the only thing there.
Please run through this and let me know what you find. Thanks
Dec 29, 2021 at 4:06 PM
