1999 GMC Sierra check engine oil level
1999 GMC SIERRA
84,000 MILES • V8 • 2WD • AUTOMATIC
STICKFIXER
The check engine oil level light will not go off.I have already replaced the sensor and it still remains on,also hade the oil changed so i know the oil level is ok.Thank you for your help.
Jun 15, 2009 at 6:03 PM
This sensor you have replaced is for the oil temperature sensor-you need to check the oil pressure switch and the oil pump. This 2 can caused the problem to include engine bearings
Jun 15, 2009 at 6:10 PM
STICKFIXER
The sensor I replaced was the low oil level sensor.The light went off after a few miles of driving,I guess the computer needed to reset.Thank You for the help,stickfixer
Jun 17, 2009 at 5:56 PM
