1998 GMC Sierra Suspension
1998 GMC SIERRA
CARRIEACKLEY
I have a 1998, GMC, Sierra, Pick Up, 5.0 V-8, with 103,000 miles on it. It was in an accident, the entire drivers side of the truck hit the curb. both tires on the drivers side were damaged. The drivers side tie rod busted. The suspension is damaged in some mannor and I am not sure to what extent. After replacing the tires and the tie rod, the front tires apear to have a slight tilt to them. The entire truck rocks when I try to drive it. I have checked the bushings and all appear to be fine. the sway bar looks the same with the exception of a slight smuge leaning towards the passenger side of the truck. what is the most likely item to be replaced/repaired next?
Carrie
Apr 17, 2007 at 12:53 AM
AUTOPOP
  • 49 POSTS
Have you check the lower control arm and it's bushings also spindle/knuckle may have damage also.
Last thing to check is bent frame.
good luck!
May 18, 2007 at 11:34 AM
