1998 GMC Sierra
1998 GMC SIERRA
JOYCEMARIE
1998 GMC Sierra
my windsheild washer does not pump fluid. The lines are clear and the fuse is o.k. Where is the pump and the washer switch locted on this vehicle. Any help is appreciated
Feb 15, 2010 at 2:29 PM
HMAC300
  • 48,601 POSTS
if you are sure the lines are clear and not frozen with water then the pump is at the bottom of the tank that you put washer fluid in. you'll probably have to pull the battery and box out to get teh tank out to fix this. lso sometimes the pump works but the impeller spins on it.
Feb 15, 2010 at 5:20 PM
