i NEED TO REPLACE THE WINDOW LIFT MOTOR.HOW DO i REMOVE THE WINDOW
May 17, 2009 at 9:44 AM
DR LOOT
CERTIFIED EXPERT
replacing window regulators can be very tough especially on the truck you're working on, you will need to unbolt the entire inside of the door support, or with a drill removed the rivits not hold the motor to the support, you better purchasing manual to help you.
