1996 GMC Sierra 1996 GMC Sierra stalling in drive
1996 GMC SIERRA
14,000 MILES • V8 • 4WD • AUTOMATIC
NOAHWA
A few weeks back my truck started to stall when I'd hit the gas, usually it would just lurch and then fire up again, then it would drive fine. Lately it's gotten worse and has begun stalling as soon as I put it in drive. Idles fine, just stalls in gear. I switched out the fuel filter but no luck.
Any advice would be appreciated. Thanks.
Jun 20, 2010 at 3:34 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 21, 2010 at 3:33 AM
