1995 GMC Sierra throttle position sensor
1995 GMC SIERRA
50,000 MILES • V8 • 4WD • AUTOMATIC
DASOLOMON39
can the throttle position sensor prevent my 1995 gmc truck from starting?
Mar 22, 2009 at 7:48 PM
It will cause the engine to idle funny and hesitation problems to include fuel and ignition timing demands
Do below to determine if its fuel or spark problem.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 22, 2009 at 8:35 PM
