1995 GMC Sierra replace water outlet, thermostat , and seal
1995 GMC SIERRA
68,000 MILES • V8 • 2WD • AUTOMATIC
VICLED
Radiator Fluid ( the green stuff) is leaking from the housing (water outlet). I'd like to replace the water outlet, seal, and thermostat.
How do you do that?
Mar 5, 2009 at 8:40 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me the specific model you have, C1500, K1500 etc. Also the engine size in liter and the 8th digit of your VIN.
If I understand you correctly your water pump is okay, you just have a lead on the housing the thermostat is in and you want directions to replace.
Why do you want to replace the housing also?
Have you checked the torque on the housing bolts to make sure they are tight and that is why it is leaking?
Mar 5, 2009 at 10:26 PM
