Noises problem
1993 GMC Sierra V8 Automatic 101K miles
A vent door appears to be popping open and closed when ever I turn the key on and when I turn the key off. It stops after about 30 seconds. I replaced the electric actuator on the driver's end of the ac/heater duct..No luck. I don't think I'm getting voltage to the actuator. Have checked all the fuses I could find including the engine near firewall. Can you tell me where the power for this actuator comes from and if it is fused and where the fuse is located. I can't find a wiring diagram anywhere.
Thanks,
Jack
Thanks,
Jack
Sep 17, 2008 at 4:06 PM
