2005 GMC Savana Two Wheel Drive Automatic
I have a 2005 savana van and am having difficulty filling the gas tank. I am unable to position the filler nozzle so that it doesn't click off. Also I must barely hold the nozzle on so that the gas is pumped as slowly as possible or it backs up the fill tube and shuts the gas off. I have looked under the van and there is no kink in the line and I also pushed a piece of clear plastic tubing into the filler neck about 24" and found no obstruction.
Can you help me? It takes about 45 seconds to pump in a gallon so you can see that it takes a long time to fill the tank with 25 or so gallons. Help!!!
Oct 2, 2009 at 6:19 PM
