2005 GMC Savana A/C stopped blowing air
2005 GMC SAVANA
137,000 MILES • V8 • 2WD • AUTOMATIC
CAMPBELL93
I have changed the blower motor and the resister and the A/C still isnt not blowing any air. I can feel the rear air is on and getting cold. So it the front blower motor. The resister is now getting super hot, like crazy hot. Now I didnt change the wiring harness but I have checked all the fuzes and inside and out are fine. What else could it be????
Aug 16, 2010 at 12:15 AM
When you installed the blower motor did you check it if its working. If so and you've changed out the resistor-your problem is coming from the HVAC control assembly/blower switch
Aug 16, 2010 at 1:03 AM
CAMPBELL93
Ok where is that? or is it the head unit in the van... the blower motor works and the resistor has power so where is the HVAC control assembly/blower switch?
Aug 16, 2010 at 1:07 AM
Its the AC head unit
Aug 16, 2010 at 1:09 AM
CAMPBELL93
ok is that why the resistor is getting super hot... like hot ehough to melt the plastic....
Aug 16, 2010 at 2:05 AM
Sounds like its shorting out check the wiring from the head to the motor
Aug 16, 2010 at 9:46 AM
