2002 GMC Savana
2002 GMC SAVANA
STRANGER
Engine Performance problem
2002 GMC Savana V8 Automatic 176700 miles
got code p0302, its a box truck like the ones from Penske don't I know how to access the sparkplugs they are under very far to reach.
owners manual doesn't show.
thanks[img:8b3aed217a]http://www.2carpros.com/forum/automotive_pictures/188551_DSC_1144_1.jpg[/img:8b3aed217a]
[img:8b3aed217a]http://www.2carpros.com/forum/automotive_pictures/188551_DSC_1145_1.jpg[/img:8b3aed217a]
May 9, 2008 at 7:48 PM
MASTERTECHTIM
  • 4,750 POSTS
you should be able to access through the wheel well or from under vehicle.
May 9, 2008 at 7:57 PM
ALHARJ
  • 9 POSTS
Remove engine cover: 2 - 10mm screws on each side top and 4 - 10mm nuts (2 top behind lower-dash panel) & 2 at floor. remove junktray & unplug cigarette lighter cable on left. remove heater duct (2 pieces). undo 2 belt straps at floor hooks. slide engine cover straight back, with support to avoid tearing foil insulation underneath. 2 rear plugs on driverside & 3 on pass.side are accessible. jack frontend at center to provide clearance to work over tire in wheelwell behind splasguards and access 2 right-front & 1 left- front plugs. plugwires have metal heatshield sleeves.
Carefully slide enginecover over engine, supporting as best can be to prevent tearing insulation, latch straps to hooks, replace ductwork, plug in ciglighter cable, bolt it up, replace lower-dash panel and junk tray.
Dec 31, 2008 at 6:37 PM
